4Runter's Maintenance Thread
4Runter
Step 1.
Lift the truck!
Step 2.
Go back to the dealer because they forgot to give you some parts you ordered. On the bright side, they had this in the showroom.
My truck:
3.0 V6
4x4
Automatic
128k Miles
Here's the run down of parts I ordered from the dealer:
35178-30010 TRANS GASKET
12157-10010 GASKET
35303-35010 TRANS STRAINER
12204-65010 PCV
00295-01281 GASKET SEALER
23300-65020 FUEL FILTER
90919-21579 WIRES
19102-70160 ROTOR
19101-65040 CAP DIST
+Assorted crush washers
Amsoil dealer:
Front Differential
Rear Differential
Transfer Case
Transmission
Engine
Drained and replenished the oils, but ended up not dropping the tranny pan. Will periodically drain the tranny and add oil, repeat until it is cleaner.
Also changed the fuel filter.
Pulled the spark plugs. I'll let the pictures do the talking.
