4th Gen 4runner Engine Count
Which 4 Gen Engine do you have
  • Total voters
    177
TFJ-4runner
We have a lot of threads on V6 vs V8 and now that our vehicles are aged let's see how many there are of each. I'm also curious to see what the new members are going with engine wise as well. Feel free to input why you chose the engine you did and if you would choose it again.
It really didn't matter to me. My priority was to find the cleanest local private party 4Runner. Mine had the V6 and I would have bought it no matter the engine. Fuel economy was the reason I really went with the 4Runner as well as reliability. My previous truck was a 2005 Dodge Ram 1500 with a Hemi that got 11 on the highway so anything was going to be a major improvement.
We went with the V6 for many reasons:
- Not planning on towing heavy loads, father in law has a full size truck.
- Fuel economy, drive it reasonably and with a full load we returned 25mpg on a recent trip.
- Timing belt, expensive to replace in the V8.
- V6 is plenty powerful in most situations we put it in. Will be taking it to the mountains this summer, check back then:)
Either engine you have, you still have a Toyota and it will go forever and ever, most likely...
V8 for both ours and my moms T4R ('05 & '06). Went that direction for mostly towing capacity and overall power under heavier loads.
-Daniel Kent
Bought my 07 new with the V8. It was a fight to get it since no dealers had a V8 they pushed the 6 cyl. Dealer I worked at even told me they didn't make it with a V8. Another dealer told me the V8 is junk and gets awful gas mileage.
The 4.7L was in the Landcrusier, LX470 and the Tundra for years with no major problems at all. Its extremely reliable and its a V8 stuffed a small truck.
V8 because I don't wear a skirt like you V6 chumps!
haha totally kidding.
Both are really good engines, I suppose it was all of the Home Improvement I used to watch as a kid, Tim the Tool Man was an influence. More is always better.
<Insert Tim Allen Grunt>
In all seriousness though, the V8 is really smooth and reliable, quiet at highway speeds and has that extra go when you step on it.
timing belt and a little bit worse gas mileage is worth it in my opinion.
I probably would have gone with a full size pickup if I wanted a V8, probably a Silverado (no timing belt).
I just don't really have the need for it though, as I don't tow anything very large and use the 4runner as a daily driver.
The V6's were a couple grand cheaper when I was looking around. Combine that with minor fuel cost savings and no timing belt change required, and I'm ahead a few grand over going for the V8.
V8
I went with the V8, it has the power that I was looking for and it sounds great with a good after market exhaust. I had the timing belt replaced at around 106k
it was not too harsh on the wallet, had new plugs and wire done at the same time and it like a new motor again. I have no experience with the v6 in the 4runner but I know that if you take care of both of them they will last forever and take care of you.
You should add a poll at the top of this thread. I went with a v6 because I like the selectable 4wd and no timing chain. Also t4Rs in general are slim pickings. I drove up to Minnesota to buy mine. In retrospect knowing what I know now and with bigger tires,lift, and bumper I think I may have opted for the V8 to carry this extra weight around with ease. The v6 will do fine and I dont tow huge loads, but I wouldn't necessarily mind the extra power. My question is why did Toyota not make the v8 a 4wd selectable? In the end I'm happy with mine and I don't plan on selling it ever. So I guess i will just have to buy another....
I bought my V8 new in 2008. I traded in a V6 2WD T4R for the V8 4WD because I wanted towing capability (I tow an old Airstream trailer) and I wanted a 4WD V8 T4R. I also use the 4Runner as my daily driver, so I needed a truck that would function as my daily driver and one I can use to tow our old AS. Zero regrets. I would do it again.
I average 19 mpg on the hwy and 16 in the city for my daily commute. I average between 11 and 12 mpg towing at 60-65 mph. Calculated by mileage and gallons used, not the onboard computer. 78k miles on my truck.
I used to get 20 or so on the hwy with the V6. If I have to worry about the difference in 1-2 mpg I have bigger problems...
I was searching for a local 4Runner for some time. I didn't mind V-6 or V-8, but then I found a V-8 at a good price. Price mostly constrained me to the earlier years of the 4th gen. A couple things I kept in mind while I was making my vehicle search:
The V-6 had a 4speed transmission up to 2005 (I don't know how much it would have really mattered) and the V-8 has always had a 5speed.
More power vs. less power for mods.
But in the end it really came down to fiding a clean vehicle at a good price. It happened to be a V-8
I went with the V8 on both of the 4th's Ive owned because of the power. The V8 was equipped with a timing belt so it would be a lot quieter than a chain. It's used on a lot of the Lexus platforms and I doubt people would want a rattling Lexus engine. I knew that having bigger tires and adding more equipment the V8 would handle it a lot better. After having three under powered 4runners I don't want to ever have that issue again. I recently went with my friends to Tennessee and managed to only get 1 mpg less than all of their V6's. $650 every Three years justifies the benefits for me having the 2UZ.
I am not sure how you did this. Please provide us some details... Any insight is appreciated.
Simple, they drove like an arthritic senile old lady that can't push her locked up ankle past 25mph...
Did you mean the V6 has no timing BELT, as it does have a chain... Also, why do people think not having selectable 4WD is a bad thing? Its not even close to the intrusive and limiting Domestic style systems and you really wouldn't notice much difference in 2WD or 4WD with these systems (hence why many members just leave it in 4WD.) There is no earlier failure rate or wear and tear than on a Part-Time 4WD set-up, its just misinformation and older prejudice.
I also wonder why Toyota didn't make it selectable only because the system is so identical to the part-time 4WD minus one shift fork and a different shift rod, that it makes no sense.
TFJ-4Runner, Lexus's engines almost exclusively use timing chains now. The 3UR-FE, 1UR-FEL, 4GR-FSE, 2GR-FSE, ect ect all use chains. I actually don't remember if we have a current production engine that is a belt anymore. Chain drive has become far more quiet than it used to be in older Domestic, European, and Asian vehicles; they last longer, tend to be fairly reliable (at least on most Asian vehicles...)
Now then, for me I purchased the 4Runner because I needed a mid-size SUV. I looked at the FJ Cruiser and strongly considered it as it fit many of my needs, the 1GR-FE was borderline acceptable for my needs/wants.
I came from a beat-up old '93 Chevy S-10 Blazer with that anemic 4.3L Vortec that had about as much punch to it as an old lawn mower engine. That thing put a very bad taste in my mouth and I swore I would never buy anything the size of a mid-size SUV or larger without 8 cylinders, period.
The FJ Cruiser ended up being too small as I assumed I would still be hauling transmissions and engines in the back and carrying friends. The 4Runner was just the right size for my off-road needs (decent wheelbase,) comfortable/modern interior, room for passengers and gear, and the option of the 2UZ-FE. I settled on the V8 for reasons beside my bad experience with the S-10; I still assumed I was going to be hauling an extra 1-2k of engine/transmission parts in the vehicle. I also assumed that I would be towing with the vehicle (which I haven't done much of yet except recoveries.) The other deciding factor was that I fully intended to armor up, modify, and deck out the 4Runner for off-road/heavy duty use and knew that extra weight would strain the V6 ontop of my other needs.
So in the end the V8 was chosen soley for its low end torque and to provide a reasonable amount of unmodified (meaning not reabuilding the engine for extra oomph or serious regearing) power on my end-game vehicle which will have about 1200lbs (rough estimate) of extra armor, upgrades, and parts.
I test drove both and couldn't pass up the V8, even though there were plenty more V6s around. I almost settled for a V6 because there was one in great shape, but I waited another week and found the right one (my first '03). If I hadn't gotten the V8, this would have been me eventually:
After my first truck got totaled, I had to get another V8 for the same reasons.
I went with the V8 because I wanted the extra get up and go. I only have to commute to work once every 6 weeks so fuel economy wasn't a concern.
My previous vehicles for the past 10-15 years have all been Land Cruisers with the latest being the UZJ100 with the 2UZ V8. I traded it in and picked up a V^ 4th gen most specifically because I wanted the increase in fuel economy. I couldn't be happier. I don't tow anything and don't have any plans to except maybe a small utility trailer on occasion, so I opted for economy and lower maintenance costs. The 2UZ is a great engine, but overkill for my needs.
charlesz
