4th gen 4runner Heavy Duty roof rail replacement for the OEM rack.
djtc
My heavy duty cross rails for the OEM roof rack are for sale! The reason why I built these:
1. the stock rails arch and it puts the roof basket I use way too high.
2. the stock rail mounts are made out of plastic.
3. Limited adaptability for extra light mounts and high lift mount.
Advantages of my cross rails:
1.They keep a low profile keeping a mininal gap between roof and rails (About 1"). A basket will sit about 3 inches lower when compared to the stock rails.
2. Made much stronger to support more weight. The brackets that mount to the oem tracks are not plastic like the oem mounts.They are made out of 3/16 steel with 1/8 thick crossrails.
3. Cross rails are pre drilled so you can mount a hi lift.
The Cons :
Some surface rust has started in some areas. However,I could take care of that for the buyer.
The reason as to why I am selling these is because I'll be building a full length custom rack
If the potential buyer wants to add anything to the rack such as an extension or an awning mount , that can be done at an extra cost.
Lights are not included
85$ for both rails with hardware needed to mounts the rack (bolts ,washers, threaded inserts) + shipping.
I apologize for the horrible cell pics.
Rack loaded
patnewton
