4Th Gen Chat Thread
Did the TPMS bypass, misread the instructions and clipped the wrong wire and it's too close to the plug to effectively splice it back together)
Anybody have any idea of what the red/yellow wire does? On the wiring diagram, it is marked 'SIL' and looks like it goes to Data Link Connector 3 [MENTION=66389]BlackWorksInc[/MENTION]
See PDF diagram here. Unclear to me what it does/where it goes
http://www.toyota-4runner.org/4th-gen-t4rs/50252-tpms-light-bypass-switch.html
Besides MetalTech, any other good rear bump stop drop options
or is 2" blocks of metal really worth $70 :snacker:
I'm planning on upgrading my tail lights to the LED ones and was wonder for those who has upgraded their tail lights.
Did you go OEM or aftermarket? I found a set on ebay for $120.
Convince me
Weld-on vs bolt-on sliders?
Weld on if you use them. My brother had bolt-on All-Pro sliders on his FJ which bolt directly with 3/8" plates to threaded nuts on the side of his frame. After a little over a year of wheeling the 3/8" thick mounting plates peeled up and no longer mounted flush to his frame. We ended up welding on his bolt-on sliders higher up for his 1.5" body lift. Weld on sliders seem to be cheaper, aren't difficult to touch up spray paint, and not difficult to cut off if you need to for whatever reason. You won't have any mounting issues either and can be mounted wherever you want (higher up if you have a body lift).
I'm just not too trusting of bolt-on strength, weld on seems to eliminate that weakness.
Convince me
Depends on what you use them for.
Weld on - stronger, rock crawler, constant bashing, okay if you're comfortable with welding to your frame.
Bolt on - easier to install/uninstall if needed, weekend warrior, occasional bashing, "overlanding"
I went with bolt on white knuckle offroad products and couldn't be happier. They certainly hold up the full weight when crashing down on them but I also don't rock crawl so they won't see too strenuous of use. I sure am glad I have them every time they hit though!
100% agree. I also went with White Knuckle bolt-on sliders. They are awesome. I have (accidentally) ridden a rock down the full length of the driver's side rail with zero movement. I have also jacked my 4R up by the sliders with no movement. That said, I would not rock crawl with them, but I don't do that anyways so . . .
I'm looking into gears. V8, 35s and a lot of armor...
I'm thinking a larger rear axle makes more sense than regearing the factory 8". How many of you have swapped to a larger axle and which one? Leaning towards 4.56 gears and F/R lockers
Couple options I'm looking most at are
8.2" from 2010+ FJ/4R (direct swap)
9.5" from JustDifferentials (direct swap)
9.5" from a 2nd gen Tundra (Cheaper, but requires welding spring, link mounts, sourcing 6 lug hubs and drilling driveshaft flange)
Feedback ya'll. Or thread links, if you know of somebody's who's swapped rears. Quick search didn't land me anything useful
Has anyone ever looked into these brake conversion kits? They seem to be compatible with some 4th gens, gx470s and some 100 series Land Cruisers.
I’m considering preemptively trying to make the master cylinder/abs/monstrosity more reliable and I may go down this path if I can get the company to respond
It’s interesting that some of the 4th gens are supported, but not all. I thought they all had the same unit.
http://www.powerbrakeservice.net/toyota.html
As far as strength goes, seriously consider a Ford 9" third member. The design, the hypoid angle, the fact that a boss 302 can't tear it up, and neither can an F-250...
I don't believe you can get 4.56 gears from just differentials. I may be remembering the Toyota 9.5"though. When I called them originally about new gears they said they only have 4.88 and 5.29. again, that may be for the 9.5"
If you're worried about tearing up nitro gears, tell the guys at just differentials. They just might chuckle at the idea.
Sent from my XT1710-02 using Tapatalk
End-goal for me is to reliably fit 37's w/ front and rear lockers and a lower range t-case so I've been doing some research.
Somebody PM'd me a while ago and I did a quick write-up for them on my opinion with some numbers thrown in. They had asked about my ECGS rebuilt 8" diff. Some of it you may already know but for anyone that is curious here it is.
**Disclaimer: This post mostly benefits those that do serious high-traction rocky trails where low range is used, and greater than 33" tires are equipped.
Currently mine and my brother's ECGS rebuilt diffs have been doing fine, but really only have a half-dozen of rock crawl outings with mine so far (35's). If you look around the forums on build threads with broken 'original' rear diffs guys aren't back the next weekend posting another broken gearset from what I have seen (maybe they are more cautious with the skinny pedal, but it seems the rebuilt diff is stronger) The stock gearset with 120k miles and the crush washer with 34's or 35's in my mind is guaranteed to break after a couple heavy trail runs/obstacles if you are not the utmost of careful (which is no fun, makes me sweat more). As I have posted before, guys on this forum inevitably seem to break their original diffs once they move up to 34's or 35's.
If you had front/rear lockers (recently rebuilt diffs with solid pinion spacer) I could see potentially less stress being put on the diffs due to less wheel spin/speed on the trails. The rebuilt diff w/ solid pinion spacer is way better than your 10yr old diff with a crush washer. If you added a crawlbox (Marlin tacobox, $2.5k) or aftermarket t-case (Atlas) with a lower 'low range' gear ratio you could probably easily get by with rebuilt 8.0s as a guy from Marlin runs 40" tires on a 3rd gen Tacoma with their tacobox (their rear diffs might be a little stronger though). With the tacobox you have way more control and time to 'not break' stuff. I've also heard the lower gearing helps a ton with rock crawling capabilities.
I'm not sure how much stronger the 8.2's are as they use the same size gears (or maybe slightly bigger?), they just beefed up some things to hold the gears more rigidly I guess. You don't hear of too many of these diffs breaking, but they are found in newer trucks that don't seem to wheel as hardcore (or have as big of tires generally speaking). The one I did hear of breaking (newer FJ) they broke an axle instead of the gearset, after ~7 years of wheeling with 35's. Personally I wouldn't spend too much money on an 8.2 upgrade, it's not really proven in my mind yet, but if you can sell your complete stock diff you could recoup some cost and if you can find a good deal on a used one it should bolt right in.
My brother just told me ECGS can build a mostly-complete 8.2 diff that you can throw your existing axle shafts/bearings and things into. You might want to ask them about this (it doesn't appear to be on their website) and if you do, I would be curious to know the details. I just looked and JustDiffs.com
does the same thing, cost with ARB/4.56/chromoly axles is $3800 plus shipping.
It really depends on what expectations you have for your truck. If you are more careful than most, do medium difficulty trails with 33's close to home, and rebuilt your old diff with a solid pinion spacer and locker, I would wait to see if that gearset goes before thinking about upgrading. If you throw on a set of 35's and walk the thin line of your truck's capabilities, I would definitely consider the 8.2 if not more, especially if you occasionally wheel 1000 miles from home like me. My brother's ECGS gearset in his FJ has held up fine with 34's, after his stock gears died, for 1.5 years but he has a Diamond 9.5" diff on order because he is planning on 35's or larger, a bunch of other stuff, and doesn't want to break down in Moab or California when we are on vacation. I have a similar plan when I have the time/money.
You said you like the elocker option, in some ways it is nice and cheap, with the ARB you can have more things go wrong (seals blow, air mixes in with gear oil, etc) and needs an air compressor setup, couple hundred bucks more.
In summary, here are the options as I see it with prices mostly from my brain. Not knowing what tire size, gear ratio, or trail difficulties you want to run in the future, I listed about everything that made financial sense. The FJ guys have a good option that we don't have as cheap, which is sending in their elocker 3rd member gearset for a rebuilt gearset. Ours would be a couple hundred dollars more I would think, for that exact option because we don't have a rear locker from the factory.
* An ECGS rebuilt diff has a 5 year warranty with 35" or less tires.
* Regear will require additional cost of regearing front diff as well (check ECGS for prices)
* Recoup costs not include in estimates.
I'll say it again, this is a pretty rough estimate of costs depending on shipping costs, what spare parts you sell, or what locker you choose.
  • $0 Stay with 33's and hope to not blow the diff knowing that it could break if pushed hard, if you do rebuild/regear/ARB.
  • $600 Find used 8.0 3rd member with elocker unbuilt 3.73 gears, and retrofit.
  • $800 preemptively rebuild existing 8.0 to avoid paying tow truck and trail-shame, regear/no locker.
  • $1200 Find 8.0 3rd member with elocker already rebuilt/regeared (Or send ECGS your non-elocker + added cost for an elocker diff).
  • $2000 junkyard/used rear 8.2 w/ elocker, sell current 8.0 assembly to recoup cost.
  • $2800 junkyard/used rear 8.2 w/elocker/rebuild/solid pinion spacer/regear. Sell current 8.0 assembly to recoup cost.
  • $3300 Marlin crawlbox with ultra-low gearing for added control/capability plus preemptive 8.0 rebuild/regear/ARB.
  • $3300 ECGS Dana 60 w/Ox locker, reuse stock shafts, can upgrade to chromoly 30 spline shafts later if needed ($500) and is stronger/bulkier than the 8.2
  • $3500 Just Diffs/ ECGS 8.2 with standard axles/ARB/regear. Sell 8.0 3rd member to recoup cost.
  • $4000 Just Diffs/ ECGS 8.2 with chromoly axles/ARB/regear. Sell 8.0 3rd member to recoup cost.
  • $4500 ECGS Dana 60 with 35 spline axles/any locker/regear. Sell entire 8.0 axle to recoup cost.
  • $5500+ Currie F9/Diamond 9.5" ARB/regear necessary. Sell 8.0 3rd member to recoup cost.
  • $8000 Diamond housing w/ Tundra 10.5" gears. Sell entire 8.0 axle to recoup cost.
Maybe this makes you more confused, but I hope it helps you out. If not it's a good reference for me to look at... Might make for a good thread some day.
Also, my brother put together this guide for axle basics/terminology.​
A Ford 9" is nice, drop-out 3rd member design like Toyota's, but it's ground clearance/driveshaft angle is pretty awful, a D60's is probably better. Though the D60's R&P might be a bit weaker.
Not really worried about nitro gears overall, but even with nitro gears, 35s and an 8" is still pushing your luck. Know of several failures from guys on 35s. Granted, they aren't as catastrophic as stock gears, but any broken teeth is still a failure
Solid summary with one change.
ECGS D60 w/Ox locker, reuse stock shafts: ~$3300 from ECGS, can upgrade to chromoly 30 spline shafts later if needed ($500) and is a stronger option than the 8.2
99% sure I'm going that route, about 800 more than my current estimate for sourcing and building an 8.2 ($2400 +/- shipping etc) Only downside is there's no third to drop out, but for moderate/heavy wheeling I don't expect having to touch it again with just 35s. Short of a SAS, the front diff/cvs will be an issue long before the rear would be.
Well stock shafts are 27 spline so upgrading to 30 spline will need a few changes I would imagine, like rebuilding most of the axle but I guess doable. Still stronger and cheaper than the 8.2, if not a little bulky. The OX locker doesn't seem like a bad option, but if you get an ARB locker for the front might as well have an ARB in the rear too.
Exactly my thoughts with the dropout and not needing to touch it if sized correctly.
I'll add it to my post.
EDIT: Stock shafts are actually 30 spline, it makes more sense now.
Lol you sound like you've repeated a lot of this in your head a few times and now you know the pros and cons of every major design.
If you guys wait until I break my gears I'll tell you what the 8.0 can really handle with the ARB carriers/lockers and 35's
I started going down this rabbit hole once. Pretty sure I'm happier just saying screw it and picking the easiest option. Everything has weaknesses where something else has strengths. I'll upgrade when I trash the axle housing and have a better reason.
[MENTION=119029]NinjaOne[/MENTION]
I was wrong, stock shafts are 30 spline so what you posted above makes sense to me now.
erinobr2000
