4th gen Cluster...Please look and ID
TOY2G
can you tell from this picture if this gauge cluster is from a 2wd or a 4wd T4R 03-05
I have to buy one and it has to be the 4wd to have the correct lights..
thank you.....i have found several, the one with the turn signals in the speedo are from 06 and newer, I am not sure they would fit my 03. have also noticed that alot of them have P-N-D-3-2-L and my two V8 runners have P-N-D-4-3-2-L... I wonder if that matters.
03-04 runners had a 4 speed tranny. 05-09 had a 5 speed. I don't know if that affects the cluster.
That 5-spd must've been an option that came with the 03-04 V8 models, because if your gauges' numerical shift indicators start at 4th gear, then you have 5-spd trannys. The numbers listed will always start with the highest non-OD gear. That would mean the cluster in the OP is for a 4-spd model.
both of my 03 have the 5 speed at least have the P-N-D-4-3-2-L shift pattern..
but if they did not come with the 5speed until 2005 how could I have it in both of my 2003????
perhaps it is because both of my 03s are V8 and the v8 may have come with the 5 speed not the standard 4 speed.
Thank you both for your input, at least I know that the P-N-D-4-3-2-L patterns is what I need....I will see what I can find...I wish I could find a way to tell if it were 4wd vs 2wd...
Tx470
