I'd start with looking up and listing what all the codes represent.... also give us more details about it: whats the year, trim level, engine, and 2wd or 4wd? What lead up to this issue happening?
Yep...these codes are all over the place so they kind of tell you nothing. You've got a fuel injector, brake master cylinder, and engine immobilizer issue. Not likely these all just decided to die at the same time.
Typical of the ECU not getting enough power... either alternator is not providing enough current of battery is having a hard time. I'm voting on the alternator.
Sorry i was not able to reply sooner! Alternator is pumping good power,left rear wheel bearing was Mking lots of noise replaced but lights still on! Im waitting for a abd2/abs scanner and i will erase them all,then see witch one comes back first and then take it from there! 2007 sr5 4x4. Stock. Thank you guys i will update once i get the scanner.
