4th Gen Hood Rock Deflector
Dusty Driftwood
4th Gen Rock Deflector - Hardware
When I bought my (used) T4R about a month an a half ago, it came with the factory hood bug/rock deflector, which I assume was installed by the previous owner. Shortly after getting it, I took it apart to size up the grill for a plasti-dip coating. Well, when I went to re-install the deflector, the hardware fell apart in the process.
I called Toyota and they wanted $45 for a new kit, which included all the hardware. I didn't need all the hardware, I just needed a few of the rubber gromets that fit into the holes in the hood at the attachment points. I asked if the dealer had any "laying around." Of course, they didn't. So I was off to Home Depot.
At Home Depot, I found "Expansion Nuts," but not in the right size. So, I tried Handy Man Hardware/True Value, where I found 6/32 - 1/2" Expansion Nuts that just needed to be modified and they did the trick. Here is a quick "How-To" on how to save $45 if you have the same problem I had with your rock deflector
Here is the Expansion Nut
IMAG0193.jpg~original
First, you have to cut it in half
IMAG0194.jpg~original
Once you do that, you have to peel the outter rubber of the threaded (inner) part so it is clean, like this.
IMAG0195.jpg~original
Now, take the upper half and cut a slit down each of the sides. This will make it easier for you to get the metal threaded part wedged in there.
IMAG0196.jpg~original
Now, wedge the threading into the top part with the stopper.
IMAG0197.jpg~original
This takes a little doing, but once you get it in there you can then insert that newly constructed piece into the hood and screw the deflector into it. I find these to be heavier duty than the OEM parts, so I actually replaced all of them. I used the 6/32 - 1/2" Expansion Nuts so I could re-use the OEM screws.
TOTAL COST: .62/Nut
I gladly saved $44 and had a little fun in the garage while I was at it. I hope this helps someone, because I was at a loss when these parts disintegrated in my hands as I took them out. I sure as hell wasn't paying $44 for something I knew was worth a few cents, so I'm glad I found these.
Regards,
That's cool.
My rubber grommets that fit into the hood itself (the ones that squish and expand when you put the small machine screw into it) dried out pretty quickly, but i never took mine out so i left them alone. However, i think the dealership replaced it once w/o me knowing. The thing is, they replaced it with some plastic "pin" that holds it secure. Only thing is that the "pin" was too long in length, so i can see a little dent-ish thing, where it looks like it pushed UP inside the hood. Im not going to complain, cuz im sure their heart was in the right place, and the hood is a little FUBAR...which brings me to my point (sorry so long-winded):
I did a little modification to my hood protector, and here's the short version as to why: Had dealer install the hood protector one day i was getting a regular oil change done. They forgot or just DIDNT put those stick-on silcone pads on the hood to prevent scratching or rubbing. i caught it some time later, but the metal brackets had gone thru the CC, paint, primer and into the shiney steel! i was PISSED.
My fix was to 1st fix the damage on the hood (wire brush the steel, then use a high-grit sandpaperm alcohol, 3x primer, 3x paint, 2x CC, been fine since) and i put a "spacer" inbetween the hood and bracket. I used a combo off a round silicone pad (the ones that go on the bottom of chair feet) and a felt pad as well (again, used on chair feet). Its done me well thus far.
I just received my Toyota hood protector and lost two of the rubber well nuts before I got a chance to install it. I went to Home Depot and found suitable replacements in the specialty fastener section. I got 5 expansion nuts (one extra just in case), and a pack of machine screws for under $5.
The expansion nuts are course thread #8-32x15/32" and the screws are #8-32x1/2". They fit into the hood perfectly and seem a bit sturdier than the stock pieces. I will attempt the install this week.
WellNuts.jpg~original
I know its been quite some time since this post but has anyone else used this hardware that RafRey got to install the hood protector? Would be nice to use something without modifying it like Dusty DriftWood had to.
Giordano Schoenwetter
