Although this is my first post, I have been reading this forum and YT for some time now. I'm finally taking the plunge and going to do work to my '03 4R. I have a couple of questions first. If anyone can help, I really appreciate it.
#1 Is the general consensus about front lifts that the Donohoe setup is the best on the market at the time?
#2 For the rear, I would like to eventually go with what Donohoe comes up with later in the summer, but for the time being would spacers suit me fine? I'm concerned after all of the NE hoopla around here and YT.
#3 I have not see anyone mention it here, but has anyone tried the lift method on a 4Runner that Four Wheeler did on the Trailex? Is it possible to just do what they did and cut the bottom shaft of the coil over and weld a 2.5 inch spacer? It seems like it would be vastly cheaper than the Donohoe setup above, but still proven over the Rubicon. Am I missing something? Also, it would allow me to not uninstall my X-REAS.
#4 When I talked to the folks at Off Road Wherehouse, they mentioned that I had to replace my stock 17's with different rims so they won't rub when I put on 33's?!? What gives, if I get 33's on 16's vs. stock 17's, what difference does the rim make? If the tire radius is the same, shouldn't they both not rub? I understand you want more rubber when offroading, but there's a cost concern.
#5 Lastly (sorry, I didn't want to break this up in separate threads), I have no garage, so I can't possibly do the work myself. I'm in San Diego, so I was planning on going into ORW do get the work done. Does anyone have any experience with them? I'm concerned that they will be overpriced due to how much business they bring in here in S.D.
Thanks for any help!
