I don't think you have any problems if you get some helps from your buddy. All you need is an electric or air grinder to sand down the thickness of the buckeyes (Lower part of the front shock where it connects to the chasis). I've to grind it down from 41mm to 39mm. Also, you need a drill with a cone bit to enlarge the mounting holes on the rear chasis for the rear shocks.
BTW, use a long prybar as a leverage when working with the front. This is a one man job and I was manage to get it done in less than 3 hrs with profesional tools and a lift. Good luck
