4th Gen No Codes No Start & Battery Light On, It's not the battery!
V8Man
Member
I am having an absolutely unsolvable problem with my 2004 Supercharged V8 Sport. It started when a borrowed a trailer from work. After pulling it 45 miles I put my truck into reverse and everything started happening! Lights, buzzers, just chaos. I unplugged the trailer everything seemed fine except the zero point calibration skid control lights were on (VSC & ABS). I plugged in my code reader and it showed no codes. Apparently the back-up lights shorted from my plug to the trailer, no fuses blown.
Since I was on the sloped driveway, I opted to drive back in the morning with the trailer unplugged without doing the zero point calibration. After the uneventful trip back, I dropped off the trailer and parked. At noon I left for lunch and truck started fine. When I returned from lunch the truck wouldn’t start. With the key on, everything seemed fine. In the start position, nothing clicked, nothing happened. I called a coworker who brought a jump box, the truck started. I drove to the fleet shop, to check the battery or charge it. Turned it off, then tried to start and nothing happened just like before. Put the jumper on it, nothing.
I plugged in the code reader. No codes. No check engine light. The only thing showing were the skid control lights on the dash. Even though the code reader showed no codes, I cleared the codes and the truck started! I repeated the stop/start sequence a few times and everything was working except the battery charge light was now illuminated. I returned the next day with my extra relays and fuses. Checked everything, no bad anything. The alternator showed it was working by putting out 13.9 volts. I drove home and used the truck the next couple of weekends and everything was working, except the battery light was on.
I have an extra alternator. I removed the original one and took them both to have them tested. The original tested bad, the extra one tested good. Battery tests good too. Installed the extra one, the battery light stayed on! Re-tested the original and it tested good, damn O’Reilly’s. I tried to do the zero point calibration and it wouldn’t reset. I’ve had trouble with this before so I left it for another day.
So while I was scratching my head on the charging light, I continued driving it around until this weekend with the alternator still putting out 13.9 volts. Three times the truck would not start. Turn the key nothing. All three times the code reader shows no codes, but after clearing codes it starts first time.
What I have deduced for the charge light, that either the diode in the charging light circuit in the instrument panel is out or the body B4 ECU is faulty.
The no start no code can only be from the engine ECM. I have researched this and found that other Toyotas have had similar problems resulted while backing a trailer. But no one has a solution. Remember. I replaced all the affected relays. Checked or replaced every fuse that deals with gauges, trailers, brakes.
Any Ideas?
This sounds like a tough one..but the only thing you haven't mentioned is did you check all the connections, especially the ground wires from the battery to, chassis, engine, etc.?
I would suggest you check the Power/Ground wire from the battery terminal. And about the Zero point calibration, I had done that before, some more expensive scan tool can do the job. If your scan tool doesn't come with this function, if I remember correctly, you can use two metal pins to short certain 2 slots from the OBD2 connector, then ABS light and ESP light will flash and then go off. Just google how to do Zero point calibration. Good luck!
Could also be the starter solenoid. Contacts and plunger wear out and you get exactly the symptoms you described.
Sent from my HTC 10 using Tapatalk
Sounds like the starter. Try hitting it with a hammer next time it doesnt work just to be sure. :target:
Buy a new starter. AM OK. :violin:
I've replaced 3 starters in my 2005 V6 4runner.
On the V6 the solenoid is built in the starter, and easily removed. You replace the whole starter. Banging a starter will work once or twice, but that's it.
I paid $90 for an AM starter at Amazon, and it's been working for two years. In my experience no starter for my 4runner has lasted more than 4 years - including the OEM (which I had rebuilt once - and lasted 1 year before failure).
You wrote " If it’s the starter solenoid, why does clearing the codes on my OBDII scanner allow the engine to start? ".. VERY STRANGE. ASK A DEALER.
So... you carry that OBDII scanner everywhere? My 2005 4runner has never thrown a code in 15 years and 150,000 miles. My 4runner was built by the Japanese in Japan. I live in the Bahamas and 4runners are imported direct from Japan by dealer.
Thanks to everyone that has replied so far. It’s a head scratcher for sure. I saw where someone had similar thing happen while backing a Tacoma, but never saw a solution.
[MENTION=149207]AuSeeker[/MENTION] and [MENTION=425468]yao995[/MENTION]
Yes checked all the connections and grounds. Replaced the alternator with one that tested good too.
I have done the zero point a lot. I have made a micro switch with leads to make it easier. I go through all the steps, but it never confirms with the flash.
[MENTION=145671]BagiMT[/MENTION] and [MENTION=279139]Captsolo[/MENTION]
This 4Runner only has 65,000 miles. If it’s the starter solenoid, why does clearing the codes on my OBDII scanner allow the engine to start?
[MENTION=242416]PowerpointPro[/MENTION]
You’re kidding right? Do you know where the starter is placed on the 4.7 V8? If so then imagine a supercharger in place of the standard intake manifold. Read the answer above.
[MENTION=84120]nevada[/MENTION]
Yep even harder to get to with the supercharger.
feels like the ECU issue, since you have to use a scanner to erase the code every time to start the engine. What if you lose the both side battery terminals and hold them together to hard reset the ECU?(can drain the capacitors). Hopefully, it will be a simple fix. Good luck! Keep us posted.
what code is it throwing?
usually this sound like the crankshaft position sensor
usually a code p0345
what type of reader are you using?
I don't know, but it kind of sounds like whatever was wrong with the wiring in the trailer, it back fed power to something when you put it in reverse. I'm not sure what could be wrong for sure, but I'd be taking a look at the ECU and the stability control systems computer (sorry, forget at the moment the proper name). Also I'd take a look at the Park switch in the shift console, if for whatever reason the vehicle thinks it is in gear it won't engage the starter. Sorry, I don't know enough about the vehicle yet to make really educated guesses, maybe someone who knows it more intimately will chime in.
I had a similar issue last summer. Intermittently wouldn't start with no codes, no starter cranking sound and verified good battery/alternator.
It ended up in my case being a faulty fuse on the starting circuit (would need to look at the engine bay fuse box to be sure, but believe it was the EFI fuse). Fuse pin was loose. Once started the truck would operate normally. New fuse and it was good as new.
Working for Now!
Thanks again for the reply's!
[MENTION=5149]riceandpho[/MENTION]
No codes. I don’t remember the code reader brand, but it does ABS and OBDII. Never hasn’t worked and it doesn’t cause the CEL when plugged in.
[MENTION=363456]jermc10[/MENTION]
My thoughts exactly on the feedback. Isn’t the shift switch because a “clear codes” allows it to start.
[MENTION=119029]NinjaOne[/MENTION] & [MENTION=224863]Seasparrow[/MENTION]
Most likely not a mechanical problem, like lose fuse or wire. Remember a “clear codes” allow it to start.
My thoughts exactly on allowing the ECU to drain any stray stuff. I left the battery disconnected for a week, then discharged it by putting the two cable together. It has worked so far, but haven’t taken off on a cross county trip like I would have done before. Good call. The charge light is off too.
The VSC Trac and VSC Off lights still will not clear. When going through the zero point calibration procedure the confirmation blinking lights doesn’t occur. The lights go off, but come back on when the truck is moved. As I stated, I have had this happen before and after about 50 tries it finally took.
I have P0420/p0430 codes on my runner. My CEL/VSC/TRAC lights are on all the time..LOL...
Hope found the issue!
Got it, didn't catch that clearing codes allowed it to start. I read you didn't have a code to clear. Good luck!
I have seen several zero point methods. So I am not trying to be rude (so forgive me if it seems that way), but just checking if this is what you have? Also I realize you have a better setup than paperclips, just checking the sequence.
Locate the OBD port under the dash and recessed a bit. There may be a cap on it. From left to right, the top row of pins is 16-9, the bottom row is 8-1. You may notice that some of the pin holes are not used. This is normal.
Place two wires or paperclips (something electrically conductive and thick enough to stay in place) into Pins 4 and 14. Pin 14 is on the top and third from the left. Pin 4 is on the bottom and 4th from the right. It may help to tape the wires to the dash to prevent them from being pulled out during the procedure.
Park the 4Runner on a level surface and ensure the shift level is in PARK, the ignition is OFF, and that the truck remains still for the entire procedure.
Hold the wires together to create an electrical short between the pins.
Turn the ignition to ON.
In less than 8 seconds separate and connect the wires 4 or more times ending with them connected.
Turn the ignition OFF.
Separate the wires.
Turn the ignition ON. Verify the VSC warning lights go off after about 15 seconds.
After the VSC lights go off, wait at least 2 seconds and turn the ignition OFF.
Connect the wires.
The VSC warning lights should stay on for about 4 seconds then start quickly blinking. This verifies that the Zero Point Calibration was successful.
After verifying the VSC lights are blinking, wait at least 2 seconds and turn the ignition OFF.
Remove the wires from the OBD port.
Take the 4Runner for a test drive to ensure the VSC lights stay off.
Thanks to all that read and replied, everything appears to back to normal. Like I mentioned before leaving the battery disconnected for a week and then touching both battery cables together ended the no start and even turned the charging light off!
The zero point calibration that I was following was a printout from Mitchell repair, and I wasn't connecting the pins in step nine while turning the ignition on. I went to the FSM like [MENTION=224863]Seasparrow[/MENTION] recreated above.
The disheartening thing is all this was caused by an incorrectly wired trailer and none of the fuses or relays kept from causing problems with the ECM.
peacefulpiranha
