stanleybb50
As a follow up to this... Jimmy V. would not be impressed: (I guess I'm giving up on a caliper mod...)
I ordered new rotors (Centric Premium) and pads (Raybestos Semi-Metallic), and plan to install this weekend. I'm hoping that I was just jumping the gun on thinking I have a frozen caliper. Most likely its just warped rotors.
And on that note... The rotors/pads that I'm replacing only have about 14k city miles on them. (I say city to highlight that there is a lot of stop and go, but I was still hoping they would last longer). I had used the Napa Ultra Premium rotors and pads last year. The pads are ceramic and it seems like they were too much for the rotors. I'm hoping these semi-metallic pads I'm installing now will help the rotors last longer, even though I'll have more brake dust and the pads will wear faster.
And on the subject of the seizing caliper pistons.. As I mentioned above, I'm hoping they're not frozen. And I plan to do some preventative this time around. I ordered some good anti-seize (silicone based, with moly) that is compatible with rubber (links below). Seems like good stuff, and I read good things about it. I plan to remove the piston boots and apply some of this stuff to the end of the pistons to help prevent future corrosion. Hopefully this will help fend off future seizing...
www.permatex.com/products/automotiv...ake_Caliper_Lube_Hi-Temp_Silicone_Formula.htm
Bought it from Amazon here: www.amazon.com/Permatex-24115-Caliper-Silicone-Formula/dp/B000HBGKH4
Thanks again for all of your help and input into this. I'm hoping the piston boots can sort-of pop out/back in rather easily, but we'll see how it goes. Maybe I'll try to post pics of it or something.
