I believe they are programmable.RL Lemke said:What about Daylight Running Lights? I thought they were built into each 4Runner, then merely activated or not.
Swaro said:Thanks for the info. My auto door locking when tranny is placed in gear is a major PITA, and will be defeated if possible. I can't tell you how many times I've had to move the vehicle 15 feet, then jump out to raise the rear gate, only to have to go back to the door to press the button. BMW has a better idea on this...doors auto lock only at 10 mph or so.
srpage said:You do not need to go to the dealer to change when the doors lock. On my 2003 I programmed the doors to lock when the car reached 12 mph which is one of the options.
The instruction are in the owners manual and it is easy to do.
Chance said:I tiried it again with no luck.
This is what I did and maybe or probably I am doing something wrong.
I put the inigition in the ON Position.
Hold down the lock button and move the Shifter to anything but park. Most of the time I out it in R. The doors are locked at this point. I hold the power locks down for 5 sec. Then I put the car back into Park and shut off the engine. To test I unlock the car start it up and move the shifter to R hoping the doors will not lock, but it does.
So am I doing it all wrong ?
