rubberducky
...has anyone done it? I know that you should avoid running RCAs with the power cable. I assume that the battery is on the passenger side of the engine compartment (I don't have my 4R yet). If so, I'm guessing it's easiest to run power under the door sills on the passenger side. Is this correct?
Is it easiest to run RCA down the center or under the driver's side door sills? Is running them under the rug (rear seat floor area) even possible?
Thanks in advance.
Thanks in advance.
