A few quick notes on what I saw:
- Center diff was probably locked, although there is no way to tell this for sure from looking at video.
- I see both front passenger tire AND rear driver's tire spinning...and there was a big rooster tail, so this leads me to believe that center diff was locked.
- Again, center diff lock = VSC OFF. ATRAC/TRAC is still ON in all modes. 4x4 system on 4runner:
http://www.toyota-4runner.org/showthread.php?threadid=12
- VSC is the main culprit in dethrottling the engine power.
- Does ATRAC/TRAC dethrottle you? Yes, it does, but not nearly as much if VSC was ON.
- ATRAC/TRAC does bog you down if you're gentle on the throttle...remember, it BRAKES your spinning wheel, so momentum can be lost if you are gingerly with the throttle.
- ATRAC/TRAC, by definition, PREVENTS rooster tail from happening. VSC does this also by different computer logic.
- What i found on my 2002 4runner with ATRAC/TRAC is that if i were to push on the gas pedal and get RPMs above 2500-3000, ATRAC/TRAC would intervene less, allowing me rooster tail my tires. And this is what this driver did in the video i believe.
- The rooster tail on the front side tells me that the throttle was not the problem here.
- The reason why you do not see rooster tail on the driver's side rear tire is because it was barely touching the sand...in other words, the 4runner rear axle maxed out it's articulation. Notice that when the fat guy jumped on the rear bumper, you can THEN see the rooster tail from the driver's rear tire.
What does this all mean? Well, remember, ATRAC/TRAC has it's limitations. In a Hummer H2 brochure, ATRAC can transfer enough power to one wheel to get H2 up an incline of ONLY 10 degrees max. Normally, H2 can go up much steeper incline if all wheels have traction.
How ATRAC works:
http://www.toyota-4runner.org/showthread.php?s=&threadid=5036
This guy's problem was that he was bog down pretty deep in sand. That is, he seemingly sunk down to near frame height...which means there is A LOT of resistance going forward from bumpers, skidplates, crossmembers, etc.
In all likelihood, ATRAC/TRAC tried it's best to transfer torque to the wheels with traction (driver's front, passenger rear tires), but due to the load it has to go against (aka resistance discussed above), there was simply not enough power to get it moving forward. Remember the H2 example above...ATRAC can only do so much against a load whether it be sand, mud, or inclines. ATRAC can only transfer
a fraction of engine power to the wheel(s) with traction.
Notice how this guy got out. He got out by reversing himself. If he concentrated on this initially, then he would have gotten out faster in my opinion. There was less resistance if he backed up. (His front nose was touching the sand...too much resistance in going forward.) Less resistance = easier for ATRAC transfer of torque to wheel(s) with traction to work.
ATRAC is pretty hard to break since it uses existing ABS software and hardware. However, it is possible that ATRAC/TRAC went into "limp home mode" IF this guy (in video) has been off-roading a whole lot and abusing the ATRAC/TRAC. ATRAC/TRAC shuts down if you use it continuously for a long time to prevent overheating your brakes and related systems. According to Toyota, the new Land Cruiser with Crawl Control (ATRAC/TRAC cruiser control) can run it's ATRAC/TRAC system continuously for only 12 minutes before shutting down. And according to Toyota, this is pretty long for such a system. I would assume that this also applies to the 4runner's system. Do i believe that this is what happened? No, because the guy got out by reversing himself, which means that ATRAC/TRAC was still active to do so. He only had traction on two tires (one front and one rear)...so, he MUST have an active system to get out...otherwise, a vehicle without any ATRAC/TRAC would not be able to.
What are the basics in sand:
- Air down
- Don't lose momentum or you're screwed (like videos above)
- Go off-roading with a 2nd vehicle to tow you out or vice versa
Hope this helps.
