4th Gen Suspension Options/FAQ
I'm looking at leveling out my 2004 V8 4WD, and it seems like a good option is to do the Tacoma suspension swap that people are recommending, but does anybody know if the 2024-2025 Tacoma front suspension still bolts right up to a 4th Gen 4Runner? I'm looking at a great deal on some Bilsteins, but I didn't want to assume that they're the same on a 4th gen Tacoma as a 3rd gen. They're the red shocks with the blue boots, if that helps. Thanks ya'll!
Long time no see ( https://www.toyota-4runner.org/4th-...n-suspension-options-faq-215.html#post3211880) Jan 17, 2019.
Well I did lift and level my rig here is what I did five years ago and still running strong at 420,000 kms (about 261K miles);
Suspension Project (2020 prices)
Shock Absorber
Bilstein 24-239370 Front B8 5100 (Ride Height Adjustable) Shock Absorber
Bilstein 33-187174 Rear B8 5100 Lifted Shock Absorber
bilsteincanda.com $620.00 CDN ON SALE free delivery 5% discount code: REVUP
$682.08 with tax and delivery
Springs
Moog 81081 Rear Suspension Coil Spring
amazon.ca $99.35 Free Delivery
Moog 81108 Front Suspension Coil Spring
amazon.ca $147.99 Free Delivery
$277.02 with tax and 4-8 business day delivery ordered 02/03/2019
$682.08
$277.02
$959.10 Total CDN
Moog K9396 21 mm Front Sway Bar Frame Bushing CDN $14.54
Moog K80820 Rear Sway Bar Bushing Kit CDN$ 12.89
Moog K160266 Shock Mounts CDN$ 43.38
Energy Suspension 9.8105G End Link Grommet CDN$ 11.79
Tax CDN $15.12
Total $141.10 Delivered
Moog K100128 Camber Kit CDN $96.81 Delivered with tax
Coil over build x 2 (local muffler shop) & Tax Total $80.00 CDN
$959.10
$141.10
$80.00
$96.81_
$1277.01 CDN total
Moog Kit
Components that come in this kit
MOOG ES80378 [Tie Rod End] Outer $41.36
MOOG EV80379 [Tie Rod End] Inner $50.22
MOOG RK620062 [Control Arm] Complete Arm w/ Ball Joint Front Left Lower $183.33
MOOG RK620064 [Control Arm] Complete Arm w/ Ball Joint Front Left Upper $180.92
MOOG RK620063 [Control Arm] Complete Arm w/ Ball Joint Front Right Upper $177.99
MOOG RK620061 [Control Arm] Complete Arm w/ Ball Joint Front Right Lower $178.50
Separately Total = $812.32
Kit Price = $801.73 Shipping DHL = $198.06 GST 49.99 Total = $1049.78
$1277.01
$1049.78
$2326.99 CDN Grand Total
Anyway I thought I'd post this in case anyone wondered about the part numbers for this type of set up. My 4Runner is a daily driver the roughest terrain it sees is an occasional moderate Forest Service Road (FSR). More or less a pavement princess.
There's no end to the way you can go with suspension on our 4runners, but I would suggest that the bushings not be overlooked when upgrading suspension. The OEM LCA and UCA use rubber bushings that are put in tension so movement is restricted by having to twist the rubber to get suspension movement (remove your struts and try and move you LCA and UCA by hand to see what I mean). If quality poly bushes are installed you then get relatively free movement.
The next thing I did (and I'm sure many will disagree) was replace the OEM LCA alignment hardware with non-adjustable and have it positioned in the neutral position and do my alignment via SPC UCA. IMO having the LCA locked in a "cocked" position ( front adjuster forward or back, rear adjuster the opposite) makes no sense for good movement. My 4R is a pavement princess by the way.
Hello All,
New to the site but having been reading a ton of great info on suspension upgrade on 4Runners. I have a new to me 2006 4runner 4x4 SR5 no X-REAS I need to replace all four shocks and coils, I found these take offs from a 2025 Tacoma TRD (not sure if they are sport or OR) on marketplace. Can anyone tell me if these components will fit on my rig, I familiar with bottom bushing upgrade on the rears and possibly having hone out some top mounts but other than that I can't seem to find any info on the 2025 Tacoma compatibility with my 4Runner. Sorry I'm having trouble adding a photo of the suspension? If anyone has advice on adding photos that would be great too.
Thank you in advance
Hello All,
https://www.toyota-4runner.org/members/064rsr5-albums-strut-shocks-picture63562t-shocks.jpg
Did you ever figure this out?
DJNutshell
