4th Gen toytec lift
The Sleeper
Hey guys was wondering if anybody has the toytec 3" spacer lift on their 4th gen runner. If so, how is the ride quality? Was also wondering what size tires you can have with this lift. Would like to put 33" BFG ATs if possible.
Thanks.
The ride with the spacers should be pretty similar to stock assuming they are top spacers and not preload...not sure which one the toytec is to be honest.
You can stuff the 33s with some cutting, you may have issues rubbing the UCA if you are not doing different rims or adding spidertrax.
It will ride a lot like stock but you will have more stiffness. You can run 285/70/17 and should only rub during flex. Normal street driving should be fine. The tires you get will vary the rubbing though.
lindwlson982
