4th gen wheel ?
Well....I can tell you the 5th gen "snowflake" SR5 wheels will for sure fit on a 4th gen Sport (my current setup). I can't imagine why it won't work the other way around. The offset between the two is about 15mm. That's not much but ever little bit helps (and my old wheels were peeling/flaking like mad).
Thanks for the reply. I am concerned that they might not fit because of the larger brakes on the 5th gen. Hopefully someone will confirm if this is true or not.
They will fit but have less offset than the factory 5th gens. So you'll be 15mm closer to the UCA
peacefulpiranha
