4th Generation Brake Computer true or false ?
JCSTEW
Is it true that the 4th Generation 4Runners actually has a computer that records
Your braking style and as a result will make adjustments to the brake system? If this is true does the computer that does the recording start over again at some point and relearn your braking style and once again make adjustments to the brake system? Thanks for all your help.
Uhm... I don't know if it records that information in any real usable way? I mean there are FFD (Freeze Frame Data) that gets stored when some DTCs are set, but whether or not it records like a Black Box is unknown (though doubtful in this generation of vehicle.) Usually SRS modules seem to be the ones that store data like that and usually only in the event of an accident from what I understand.
OK, thank you for your insight. I thought I read somewhere that the computer tracked how you braked. From time to time my brakes act more aggressively.
johnnya
