4WD Conversion Idea.
Stuck CAPS
I've found that the A340E is the same internally as the A340F, the only differences between the two being the oil pan and the output shaft...
Would I be able to just bolt a manual transfer case onto the back of the modified E transmission at that point if the internals are the same, then run that to both diffs?
The A340E is for a 2wd V6 vehicle while the A340F is for a 4wd 4 cyl truck.
Wouldn't trying it with an A340H (4wd V6) be a better choice?
"All V6-equipped models retain the same 4-speed automatic transmission used on the previous model." -Top4runners.com
This is about the 2003 T4R.
charlesz
