In an effort to troubleshoot some transfer case problems I am having, I have noticed that the 4WD Indicator Light may be burned out on my 91. I don't have an owners manual but I assume that the 4WD light is in the instrument cluster. When I shift into 4WD, High or Low, I get no indicator light. So I decided to check to see if the light turns on with the engine off and ignition on (Bulb test for all of the other indicators) I continue to get no light for the 4WD indicator.
Can anyone confirm that the 4WD indicator actually does light up with the ignition on but the engine not running.
Thanks in advance!
Thanks in advance!
