4WD Issue
jaymo1633
Hello everyone,
I have a 89 runner V6 4WD manual transmission. I put it in 4WD High and drove about 60 yard and heard a loud grinding noise and the vehicle started to slow down. I stopped the vehicle and put it back in 2WD. It worked fine in 2WD with no issues. Does anyone have any thoughts or advice on this. Thanks
QUOTE=jaymo1633;1395181]Hello everyone,
I have a 89 runner V6 4WD manual transmission. I put it in 4WD High and drove about 60 yard and heard a loud grinding noise and the vehicle started to slow down. I stopped the vehicle and put it back in 2WD. It worked fine in 2WD with no issues. Does anyone have any thoughts or advice on this. Thanks[/QUOTE]
Your front diff probably gave up :rip:
I was driving on a paved road. I put it in 4WD at least one a month just to get the fluids moving, at least that is what I have been told to do. This is my first runner and I am learning how to work on it.
Wish I had a magic bullet to fix your problem.
Best advice - tear into the diff, and the transfer case to see what's up.
Did you check the fluid levels recently. If you were dry - that could be the leading cause of failure.
:sick:
