4wd sensors
Kevin Deshler
Ok I'm trying to find the 4 sensors that would possibly make my 4wd not work. I know there is one in the front differential, two right above the transfer case actuator and where is the 4th? I've checked the other three and they all check ok. I just need to check that 4th one.
what year....makes a difference in systems and what is and is not working.
scroll down and find my thread on no 4wd. just got mine working again
99 4wd. Light just flashes for 4wd constantly. Checked 3 sensors all ok. Check actuator front and rear check ok. Checked vac lines in front check ok. Is their a vac line on rear actuator or is that a breatger?
My 99 limited has one on the front diff. Two on the actuator. And three at the top of the transfer case at the J shifter. 2 on driver and 1 on passenger. I'm still working on fixing my 4wd as well.
2001ATL
