4WD V8 U-Haul Motorcycle Trailer requirements
v8Toyota
hello i am planning on picking up a 400cc motorcycle using a motorcycle U-hual trailer. i was just wondering what everyones experiences are with the trailer on the 4runner.
Will i require some harness adapters and or specific hitch ball mount rise/drop? i am new to this. thanks!
You shouldn't need to buy anything special, you will need a towing ball for your hitch receiver that matches the trailer's coupling size, just make sure when you rent the trailer that the rental person goes out to your T4R and makes sure they supply you with anything needed to hookup the trailer, they should have any wiring adapters, proper size ball, etc., that you need if you don't have everything, have them also go over all the connection and make sure all lights are working correctly, towing it should be straight forward with no worries on a weight limit, the motorbike and trailer weight will be way under to towing capacity of the 4Runner.
seltzernator
