Guys,
My 99 Limited 4x4 seems to not be shifting in and out of 4WD as easily as I would expect.
Using the button on the 4WD lever, the sensor on the dash just flashes after a bit, if I used the lever and lock the diff, it usually goes right away. The button by itself will still engage the 4WD but less than 50% of the time.
I always hear a little clunk shifting out of 4WD with either method. Kind of like using the button is not fully engaging the 4WD.
Any thoughts / suggestions?
The vehicle has 64K miles and it is due for a trans / diff fluid change.
Jeff
Jeff
