Mtn.Rush said:Not sure what your asking. If your in 4wd then its in 4wd foward, reverse and sideways. Or are you asking can the 4wd be engage from a parked position, after start up or stop going into reverse before drive? Also I see you have a limited, which is always in 4wd, so you need to do nothing unless you want 4wd lo range.
jimmy2x said:I have the V6 which is either rear drive or 4WD depending on what is selected. I assume that from what I've read in other posts that it would be best to be already in 4WD when pulling into the garage if snow is anticipated. Agree?
CJ3Flyr said::iagree: Remember it's not like old school part-4wd. It doesn't hurt it to drive it on dry pavement in 4wd w/center diff unlocked. There's no reason to not put it in 4wd.
:cheers:
Thanks.toto said:That's correct - the V8 is what makes it full-time 4WD, not the Limited trim package.
