4wd
Berry
OK some of you have probably answered my questions on this forum and just want to shout out Thanks! for doing so. Have not been a 4Runner owner for long so bare with me on my questions.Decided to engage the 4WD system about a block before I got into my driveway today just to see if all was OK. The 4WD shifter is in the High position. Idiot light indicated it was also in 4WD. I was at a complete stop and pressed the 4WD button in-you could hear it and feel in engage-at least that's what I thought was happening. As I was turning it felt like it was binding up or stuck and as soon as I turned the wheels she started moving again. Just did not seem right to me. Am I clueless or what? Failed to put what 4Runner I have-1998 V6 3.4L Limited
That's because you were on dry pavement and your rig was bindig due to no give. DO NOT ENGAGE 4WD ON DRY PAVEMENT. You can do this on vehicles witha center diff, but not yours. It will cause binding and you will break something. Hopefully, you didn't do any damage. Check for leaks, around the transfer case area.
That's because you were on dry pavement and your rig was bindig due to no give. DO NOT ENGAGE 4WD ON DRY PAVEMENT. You can do this on vehicles witha center diff, but not yours. It will cause binding and you will break something. Hopefully, you didn't do any damage. Check for leaks, around the transfer case area.[/QUOTE
WTF-Thanks for that bit of info-Now I really feel clueless!
That's ok, bro. Sometimes we just learn the hard way. Hopefully you didn't actually break anything. If you did, hopefully it's just a seal (which is why I told you to look for a leak).
Just to expand on pnuts post a little, the binding is happening mainly because you tried to take a corner. When cornering, all the wheels will travel at diferent speeds. The outside wheels need to go further than the inside ones, so they turn faster, and the rear wheels always take a 'short cut' and don't follow the front ones exactly, so they travel slower. Now, when you have 4wd engaged you are forcing the front and rear wheels to travel at exactly the same speed. It's ok when going in a straight line, but cornering is going to cause issues because your tires cannot break traction easily to allow for the natural rotational speed differences. The binding is pressure building up and is often called 'wind-up'.
Thanks for the reply and I will have to check in the AM for leaks-This is all I need to have happen since I just bought the 4Runner.
Understanding you are new to 4R's and the forum, so we will take it easy on you...but didnt we tell you you had no center diff in the other thread and that as such to not use the 4WD on dry pavement? :bash:
Yes you did but unfortunately you weren't sitting in the passenger seat to ask me WTF are you doing? I just was not thinking when I decided to test out the system-Now I know-I just hope I did not screw anything up-I drove about 150 yards-150 yards too many!:ybrick:
150 yards is nothing. I wouldn't worry about it at all. That wont cause leaks, or bend anything, or do anything other than maybe shave 5 thou off a tire. It takes way more than that to break stuff, and if something breaks, trust me, you'll hear it.
haha, i did that 2 weeks ago, then argued with my dad on what a bad design it was, i had no leaks that i know of and no issues and have used 4wd since (while offroading) and it worked fine.
an easy way to reconcile this if you are driving on dry pavement and do it again is lift your foot off the accelerator qucikly and then press it again, the 4wd will disengage if youve shifted back to 2wd
Thanks guys! My chest pains went away after reading everyone's replies-Thanks for being my brain and educating me on the science of 4WD!:thumb3:
The real science comes from getting yourself out of some sticky situation you got yourself into off the road LOL!!! I find myself pushing the envelope just a little bit farther with every expedition!
here check out this 1930's explnation of what a differantial is and how it works and why it feels like your going to break stuff when in 4wd when going around the corners, you can just jump to 4 minutes or just watch the whole thing, it makes it's really simple to understand.
http://www.youtube.com/watch?v=Em1zQToa_a8
and another good page that explains it , i find the little pic where you move your mouse is the best part of that page
http://www.howstuffworks.com/differential.htm
hopefully you'll read this and learn it as it applies to every car and is good information to know to keep from breaking stuff and when to use 4wd.
I am shocked to find out You tube is that old...LOL
Great information and thanks for the link.
lol i know, i think that's what makes it so good is that the video was made at the beginning of all of the differential stuff and back when things were much simpler plus you gotta love the very official voice of the early 1900's lol .
also a cool thing some people might want to check out is just the wikipages for this stuff,
http://en.wikipedia.org/wiki/Four-wheel_drive
http://en.wikipedia.org/wiki/Transfer_case
http://en.wikipedia.org/wiki/Differential_(mechanical_device)
http://en.wikipedia.org/wiki/Locking_differential
quote from 4runner wiki page
hird generation (1996–2002)
Third generation 1996-1998 Toyota 4Runner
Also called Toyota Hilux Surf
Production 1995–2002
Assembly Tahara, Aichi, Japan
Hamura, Tokyo, Japan
Body style(s) 4-door SUV
Engine(s) 2.7 L 3RZ-FE I4
3.4 L 5VZ-FE V6
3.0 L 1KZ-TE turbodiesel I4
Transmission(s) 4-speed automatic
5-speed manual
Wheelbase 105.3 in (2675 mm)
Length 1996-98: 178.7 in (4539 mm)
1999-2000: 183.2 in (4653 mm)
2001-02: 183.3 in (4656 mm)
Width 2WD: 66.5 in (1689 mm)
Limited: 70.9 in (1801 mm)
Height 1999-2002: 67.5 in (1715 mm)
1999-2002 Limited: 68.5 in (1740 mm)
1996-98: 66.5 in (1689 mm)
1996-98 Limited: 68.7 in (1745 mm)
Related Toyota Land Cruiser Prado
Toyota Hilux
Toyota Tacoma
Toyota T100
The 1996 model year marked another significant redesign of the then-aging 4Runner. Whereas the transition to the second generation 4Runner was one that kept the build quality and options roughly on par with the rest of the mid-size SUV market, the changes made in the third generation turned the 4Runner into a more luxury-oriented vehicle. This move paralleled the changes to the 1996 Nissan Pathfinder, but moved the 4Runner into a distinctly different class from its older competitors, the Ford Explorer, Chevrolet Blazer, and Isuzu Rodeo. The third generation 4Runner did, however, look very similar to the second generation.
This similarity largely ended with its looks. It carried over the basic design and concept, but executed it differently with an all-new body shell on an all-new chassis. This time, it shared virtually nothing with the pickup it had originally evolved from, and had more in common with the Land Cruiser, as it shared its chassis with that of the Land Cruiser Prado.
The third generation 4Runner also featured new engines that are also installed in the first generation Toyota Tacoma pickup trucks. :
* 2.7L 3RZ-FE I4 replacing the previous 2.4L 22R-E I4; 150 hp (110 kW), max horsepower: 4800 rpm, torque: 177 ft·lbf (240 N·m), max torque: 4000 rpm;
* 3.4L 5VZ-FE V6 replacing the previous 3.0L 3VZ-E V6: power: 183 hp (136 kW), max horsepower: 4800 rpm, torque: 217 ft·lbf (294 N·m), max Torque: 3600 rpm.
In 1996 the 4Runner was dropped from sale in the UK, to be replaced by the Toyota Land Cruiser Prado, which was badged as the Toyota Land Cruiser Colorado.
Significant changes from the second generation models include a larger body on a longer wheelbase, increased interior space, increased cargo space, twin airbags, ABS, lift-up tailgate, coil-sprung suspension all round, rack and pinion steering, and aerodynamic contour designed glass headlights. Additionally, Hilux Surf versions immediately moved to 16-inch wheels and gained a center differential, enabling the use of four wheel drive on hard surfaces without complication for the first time. The prior system was retained to give on-the-fly shifting between rear and four wheel drive as before.
1997 Models received a few minor updates, including the addition of a color keyed cargo cover.
1998 remained largely unchanged, save for a few changes in the electronics. More ergonomic switch control panels and a newly designed 4 spoke steering wheel, which also necessitated a redesign of the air bag system.
1999-2000 Toyota 4Runner
1999 Models received both major cosmetic and interior enhancements. A new "fat lip" bumper was designed, as well as new multi-parabola style headlights, projector style fog lamps, and updated side marker lights and front turn signals. Vehicles with "Limited" and "Highlander" (later called "Sport Edition") trim received color-keyed running boards, front and rear bumpers, mud flaps and flares. The ergonomics of the interior was completely changed, moving all the controls to the center of the dash for the rear window, and defrost. The Limited trucks also received a brand-new electronic temp control, and upgraded stereo.
2001-2002 Toyota 4Runner Sport Edition
2001 Models received new transparent taillights and new front grille design. The wheels were also changed to a five-spoke design rim. Limited models received newly designed five spoke wheels as well, however different from SR5 and base model. Also included was a new, sleeker side view mirror design. SR5 and base model 4Runner's also have redesigned climate control units utilizing 3 knobs and 2 buttons, contrary to the 1999 model's 2 sliders and 2 knobs. 2001 models are now equipped with Vehicle Stability Control standard.
