4x4 engaged.... Did I screw up?
I think part of the problem is the use of unclear terminology.. People seem to be attributing different things, to different words.
AWD for example. There have been MANY MANY variations of AWD over the years, as different versions came along. At some point, AWD is usually controlled by some form of computer control. The slippage limitations, for example, are usually controlled mechanically or electronically. This can happen a ton of ways. My old Subaru had AWD and it had a slightly different set up to current versions.
IN general - when one means AWD they mean a system whereby power from the engine can be transmitted in some fashion to every wheel. Different versions do this differently. AWD also, in general, attempts to limit the amount of slip at wheels. Where people who are term nerds like to stay away from this is, this implies not suburb offroad ability. We all know why. Sometimes you need to get the wheels spinning to get off the ice or mud and keep spinning until it gets solid traction. AWD usually doesn't let you do this.
Again. HOW this actually operates is usually controlled by the computer in a car and different makers do it differently.
Honestly, my v8 4runner in full time 4wd operates a lot like my old Subaru did. Almost.. not exactly.
Locking the diff, makes it act a whole lot like my old 4runner.
There are tons of specific technological differences in how specific vehicles operate.. and there are tons of terms thrown around. Full time, part time, multi mode, AWD, GOD MODE traction control.
At some point I think we get caught up in trying to claim our understanding of a term is right.. and then try to assume that our definition matches everyone else..
When it may not.
Cool. I can buy that. For me I lump all AWD into the same general category, regardless of who makes it or if not we would need to be very specific for a particular version of AWD for specific Make and model and year and options. The main aspect of AWD for me, is that regardless if it is 70/30 split, 100 rear 0 front until the front needs some power, or activated with a switch by the driver,etc... the defining factor for me with AWD is ability to drive on pavement and turn in the same fashion as if in 2wd.
4x4 is then a system or a mode that locks the center as with the 4runner center diff or in a standard transfercase of many other 4x4's and which is not recommended to used on dry high traction pavement.
What tripped me up here is not knowing that the V6's also had a center diff and always thought that was a deferentiator between the V6 and V8.
peacefulpiranha
