52K Easy Miles, Two Cracked Springs and a $7K Repair Bill – Is My Spacer Lift to Blame?
mstgkillr
Junior Member
I have a 2018 4Runner TRD Pro with only 52,000 easy miles on it. It's my wife's daily driver, and she primarily drives it back and forth to work, approximately 10 minutes each way. It has never been off-roaded, exposed to floodwaters, or involved in an accident.
The only suspension and tire modifications are:
  • 2"/1.5" Cornfed spacer lift
  • LT285/70R17 Nitto Ridge Grapplers
Yesterday, we took it to our local Toyota dealership for a brake job, just 16,000 miles after having new OEM pads and rotors installed. They recommended replacing the front and rear pads and rotors, which didn't particularly surprise me. However, things quickly went downhill from there.
The dealership identified the following additional issues:
  • Both front lower control arm bushings are shot, and they're recommending replacement of both complete lower control arm assemblies.
  • Front sway bar end link bushings need replacement.
  • Both front coil springs are cracked and need replacement.
The dealership is blaming everything on the spacer lift and oversized tires. I don't buy it!
Between the brakes, suspension repairs, oil change, and other fluid changes, the total repair bill is going to exceed $7,000.
I'm having a hard time wrapping my head around this amount of suspension wear on a 4Runner with only 52,000 miles, especially considering how conservatively it's been driven. I understand that rubber bushings deteriorate with age and that modifying the suspension geometry can accelerate wear, but two cracked front coil springs on a vehicle that's never seen a trail?
At this point, I'm trying to decide which direction to go:
  • Option 1: Proceed with the dealership's recommended repairs using OEM components and retain the Cornfed spacers and oversized tires.
  • Option 2: Eliminate the spacers and install aftermarket coil springs that provide a similar amount of lift (if there is one) while retaining the factory TRD Pro shocks and current tires.
  • Option 3: Put the money toward a quality aftermarket suspension system, such as King, Icon, or something comparable, rather than spending thousands on OEM suspension components.
My biggest concern is spending this kind of money only to find myself dealing with the same issues another 40,000–50,000 miles down the road.
I really like the current stance of the vehicle and would prefer to retain it, but not at the expense of reliability, ride quality, or safety. I also don't necessarily need an expensive, high-performance off-road suspension system for a vehicle that's strictly street-driven.
For those of you who have been running spacer lifts and 285s on your fifth-gen 4Runners for years:
  • Have you experienced anything remotely similar?
  • Is this amount of suspension wear at 52,000 miles abnormal?
  • Has anyone else experienced cracked factory TRD Pro coil springs?
  • What aftermarket springs would you recommend to eliminate the spacers while maintaining a similar ride height?
If this were your 4Runner and you were staring at a $7,000 repair bill, what would you do?
It sounds like you are being scammed. I don't see how a spacer lift can cause springs to crack. Did they show you the cracks? No way would you need new rotors after only 16k miles. Even if true, all that should not add up to $7. More like $1k -$2k.
Also, I wouldn't take it to a dealer. Find a good independent shop.
PRWhite
