5spd swap, HERE GOES NUTHIN!
So the stage 2 F1 clutch only lasted about 2 years. The super charger and rock crawling (Rubicon) took care of that. So I upgraded to the stage 3 which is a 6 puck race design. This thing bites! Can't wait to toss the Marlin Crawler 4.7 Taco Box behind it. Crawl City!!!
Installed a new seal to stop the leak while it was out.
Rear E-locker was just a dirty connection back at the locker. Easy fix.
Speedo works again too. Had a front bearing going out and the metal shavings corrupted the ABS sensor since it's magnetic.
Nice write up. My trans got a dose of strawberry milkshake and rather than fixing the auto I'm swapping in a 5 speed as you did.
Great Build!! Do you have any issues with a check engine light? Also when you pull your key out of the ignition? My 4runner will not allow me to remove my key if my vehicle isn't in park. I always wondered if that would be an issue in this swap. Once again great build!!
lindwlson982
