5th Gen Bilstein 6112 Tips-KDSS
NC14trail
Junior Member
Installed 6112s on my KDSS 2014. Here are a couple important tips/notes from my experience:
-Bilstein instructions tell you to use a one notch LOWER SETTING on the passenger side---DO NOT DO THIS!!! You will end up with an uneven lift like mine. No idea what they are trying to compensate for, but it doesn't exist on my vehicle(2014 Trail)
***KDSS--I was able to swap out the new coilover WITHOUT REMOVING the front KDSS swaybar. This made the process MUCH easier, as last time I did this, I removed it and it is a beast to get it back into place! Try it first without removing the KDSS front swaybar(I did do the install on a true garage lift this time versus in my driveway)
-I added a 1/4 inch Toytec spacer plate to the top of the mounts hoping to get it closer to 3". In hindsight I would have gone with the 1/2 inch aluminum spacer even though its a little more work(swap studs) because the 6112s at full height plus the 1/4 inch spacer still do not provide the height that the Gen1 BOSS lift did at full height (BTW-that setup was a piece of junk with all 4 corners failing within 2 years!-to their defense, they have changed the design but they are still selling that POS Gen1 BOSS setup)-never buy this!
-I am running Camburg uniball UCAs, I dont believe from my experience that you would need to replace the stock UCAs to run the Bilstein 6112s at 2.5 inch lift(full height) in the front. My feeling on the UCAs after having them several years is that they look good, but they DO NOT provide any additional benefit of extending the travel of the front suspension or any ride quality improvements. In fact, mine are to the point where after some serious wheeling this summer the uniball teflon liners are shot and so the balls need to be replaced which is a pain after only 2.5 years. If I was doing it all over again on a budget, I would roll with the stock UCAs as I think they'd work just fine, can be aligned ok and are maintenance free! If you had to swap them later for any reason, that's an easy modification.
Aside from that, I am happy with the setup overall it is a good, firm ride which I like although I do miss my extra .5-1 inch of front lift. BTW-I am running bilstein rear shocks with my leftover Toytec 3' lift springs. The truck sits perfectly flat right now(no front rake). Good luck!
Thanks for that write up. It seems safe to say that if you didn't add the 1/4 inch space up front the truck would rest slightly prone in the rear? I don't want to run the truck completely flat, I quite like a little bit of rake. Are you running the 5100 or 5160 setup in the rear?
Care to share how you accomplished that? I have 5100's in mine now on stock springs but now that I have a front bumper, sliders and full roof rack, I want to change my springs but the thought of having to deal with the KDSS is telling me to just live with the stock springs. I have access to a full lift at my convenience and even then, it was a pain in the butt. If it's really that much easier, I may just bite the bullet to get new springs. Thanks!
[MENTION=116420]NC14trail[/MENTION], did you use one notch lower on your passenger side and a quarter inch spacer on your driver side?
You only drop one clip on your passenger side if you are not using a spacer on your driver side. It's to account for the driver side lean on the gas tank. Sounds like your uneven lift is due to overcompensation for the gas tank driver side lean. If you still have spring compressors, see if you can compress the passenger side and adjust it all the way to match the driver side. They should correct your uneven lean.
I used 1/4" spacers on both sides to give it some extra height, I just dropped the passenger side coilover down one notch which is what the install directions recommended and my truck is noticeably higher on the driver side, which stinks.
seltzernator
