chayos00
Wow, you the first to report that this upgrade isn't worth it. While I agree that braking performance so far has been a relatively positive thing, in that there are no numbers of improved braking (objective testing results). However the consensus is that the brakes feel better. Good enough for me. The main reason for this mod is to prevent the stuck caliper that plague the 4th gen. So far, that seems to be the case and IMO this upgrade is worth every penny. My front calipers are currently seized and need to be replaced ASAP. May as well do all four.
I would agree that I seem to be the only one to report it wasn't worth it. However since I live in Arizona and don't see much moisture on my vehicle the calipers of 4th gen's around here don't seem to have the same issues as those in winter prone areas. Now if they are frozen, yes I would agree it's totally worth it. But for daily driving it doesn't seem to have made a difference for me vs stock.
I am running the regular Akebono pads and wished I went with the performance one's for better bite. I am actually surprised you are not happy with the upgrade. You might need to do a good brake fluid flush to get better pedal feel!
I actually did a TON of bleeding my brakes as I had installed the SS brake lines too and I put probably 6 32oz jugs of brake fluid through the whole system. First it was 2 jugs for all 4 corners and then the pedal still felt wrong, so I did another full bottle for each corner to bleed the brakes and they finally felt just like stock was. Since November braking feel has remained consistent, no changing feeling of it from how stock felt. However I've gone 4x4ing since and figure it's not a bad idea to once again soon flush the fluid due to the master cylinder getting it's full use and "flush" as I would call it using ATRAC. I doubt this will change braking feel, but it's not a bad idea to try.
I do wonder if another kind of brake pad would change the feel for me.
