What Size Washer for Rear Brake Line?
88Center
Member
Finally found the part number.
OEM Brake Hydraulic Hose Caliper Bolt Washer
47389-50020 (Front and Rear)
I paid $11.23 for each one, at my local stealership.
All brake and cv axel part numbers posted here
https://www.toyota-4runner.org/4th-...upgrade-cv-axle-part-numbers.html#post3903222
Original post:
Need new copper washers for the brake line, since I need to replace my rear calipers. Could not figure out or confirm the exact size needed. There are two washers per caliper, where the brake line connects with the banjo bolt.
Bought two new rear calipers but of course they did not come with brake line washers or banjo bolt.
Od = 17.2 mm, ID = 10.2 mm. If you can't find PM me your address I'll send you four.
Thank you!
Went down to Autozone and they barely had a few sizes of copper washers. Went down to Napa and they didn't have any copper washers.
Ended up ordering from dealership. Thanks for your offer to send!
TerryNap61
