5th gen Eibach Pro springs on a 4th gen
The-Wood
Specifically talking about the REAR springs only from the Eibach Pro truck lift kit for a 5th gen 4runner.
Has anyone used the rear springs from this kit on a 4th gen 4runner? If so how much lift did you get?
I have used stock and aftermarket 5th gen rear springs on my 4th gen they fit.
If I recall they provide an extra 1/4-1/2” depending on the model, options and weight differentiations.
What aftermarket springs?
Are you saying stock 5th gen springs gave you 1/2"?
I'm curious about this as well, I assume the spring rate is higher than the 4th Gen. I need stiffer springs for towing and will most likely talk to Eibach directly if this thread doesn't pan out.
Did anyone figure this out? I was offered an eibach kit from my buddy for 100 but it’s from his 5th gen
From Eibach's email reply to my question on 4th/5th gen spring differences:
Not too sure between the two since they are slightly different weights and heights. I would recommend reaching out to Dave in our tech department at 951-256-8414.
I haven't had a chance to get a hold of Dave to ask him yet.
31ectr0nicb0b
