5th Gen Features/Models/Differences
1engineer
Moderator
Over the past month or so we have had quite the influx of either new 4Runner owners or those looking to purchase. With them in mind I wanted to start a thread listing the DIFFERENCES between models.
For example: A LE is the only model that you can get full time four wheel drive. A TE model is the only model with KDSS, etc. Some items shouldn't be listed as differences like wheels because wheels are easy to order and install across models. Skids are another item that is easy to change for example.
I think it would muddy the water so to speak if we broke it out in the "Premium" or "Non Premium" models so we will keep it at pretty much ANY major differences between the SR5, TE, TRD Pro and LE. This means you might have to buy the "Premium" edition of the model but you can get it with that model.
So to get it started with the basic differences between models:
2015 SR5
-Conventional Suspension
-Part time 4WD avaiable
-All standard features and convenience packages
2015 TE can have all features (or deletions) that can be had on a SR5 and
-KDSS Suspension
-Multi Mode 4WD controls
-Rear E Locker
-Hood Scoop
-Front and rear TE specific plastic cladding
-Lever actuated Automatic Disconnecting Differential instead of Electric Actuated.
-Contrasting seat stitching
-Interior trim cladding a darker color.
*Delete sunglass holder
*Delete 3rd Row Seating
2015 TRD Pro can have all the features (or deletions) that can be had on a TE and
-TRD Pro Conventional suspension
-Orange Paint Color
-TRD Pro Badging (includes the front grille sleeve and Toyota logo)
*Delete KDSS Suspension
*Delete Sunroof
2015 LE model can have all the features that can be had on the SR5 and
-Push button start
-LE specific body cladding
-XREAS Suspension
-Full Time 4WD available
-Auto Headlights
-Dual Automatic Climate Controls
-JBL Sound and Speakers
-Leather trimmed seating
-Ventilated seats
-Keyless Touch Entry
-Memory Driver's seat
-Wood grain Interior
-Powered Running Boards
These are options that would be either expensive or difficult to add unlike wheels or skids. What am I missing?
Does this apply to current (2015) models only? (Obviously TRD Pro)
Since the header on each of the compared categories clearly states 2015, it is pretty obvious that he is showing the difference between the four different 2015 trims available.
Yes. Most of them carry back to 2010 and up too.
If you guys come up with other items I will edit and add them to the list in the first post.
LE only "Heated/Ventilated Leather seats"
other trims get softex seats.
premium models get heated seats but not ventilated.
Unless the header was incorrect and he wanted to adjust it to read 2010-2015. Oh wait, this is the internet and it is written so it must be true.
Please don't hate me. I will make a note to never ask for clarification for any post from 1engineer again. Good thing you "got his back". The nerve of me! Rookie mistake. If your sarcasm meter is not pegged, it is broken.
Looks pretty good, a couple of small things on the LE
LE has memory driver seat, interior wood trim, keyless entry (touch the handle),
I am using 2015 since that is the first year for the TRD Pro model but most of the differences go back to 2010 and up.
TE and TRD Pro have stick shift for transfer case, SR5 and LE have a dash knob. I can't speak for others but it was important for old school me.
Added!
*Trail and PRO the interior plastic trim is black vs. silver
*Differentiat the rear hatch windows controls limited vs others (buttons vs. need to use the key)
Maybe not worth adding but
*Trail Premium and PRO interior have red stiching
*Not sure if we wnat to get into the generational differances but the additoin of the Air pump after (2013?) and the center display being clock only vs clock, compass, mpg, etc
I'll add the stitching and interior color!
The differences like the air pump and clock happened to all models.
Trail has transmission skid plate I believe vs. SR5 and LE with none for trans. I may be wrong though.
Add in TRD PRO, and then you have a different shift knob, and TRD Skid. badging front grill.
TE, SR5, LE have different grills/color scheme and fascia. That may be something to break down as well.
Roof rails on Pro and TE have black endcaps..
Luceann
