5th Gen LED Bar Hidden Bumper Brackets Combo 15 Percent Off!!!!
Another happy customer with our 4Runner Bumper set up runing two 32” led bars!
I had the Cali Led bar in my Tacoma. Anyone have any install info or pics on did you run the wire from the Led bar thru the firewall. And use one of the empty switch areas in your 4runner to add a push button from amazon and connected to that. That is how I did my Tacoma.
I ran both my bar and pod wires in through the firewall and used empty switch plates for stock switches, looks great
Thanks Chris, Does the 4Runner have that rubber hole on the ride side of the engine to run the wire thru. I did not look yet. Also did you tap in to your fuse with the splitter off your tail light fuse? Thanks Don.
It does, I just cut a slit and ran my wires through where the red X is (not my picture but they marked where I ran mine through)
As for the wiring I ran the relay harnesses off the battery, the only wire that I had to tap was the illumination light, and I tapped the illumination wire on the wiper heater switch for both. I didn't use any fuse taps for the light bar or ditch lights
