5th Gen Limited Options to Improve Ground Clearance
Plainview604
Hi Everyone,
First post, very longtime lurker (and i mean 5+ years). I seem to have always found what I was looking for before but I have a fairly specific question.
I currently have a 2017 Limited. It has 32' KO2's on trail rims, running boards removed, rest is completely stock. I'm getting into some mild off-roading with the local club and also head out on the weekend with my son. The vehicle is a beast and i love it but im finding often my approach and departure angles are a bit lacking, ive been scraping the front and the rear a lot even going extremely slowly and with a spotter over obstacles.
I drive my rig as a daily and I drive a decent amount. If i do a suspension lift I want equal if not better on-road performance that is offered up by my XREAS. I have priced it out at our local shop here in Vancouver and anything that will achieve that feel is currently around 5-6k installed (lovely Canadian prices for you). I also don't really love the idea of ripping out my brand new suspension which is performing quite well at this point and replacing it with something that is quite harsh (whats the point i spent most of my time on pavement). Fuel consumption is another aspect, its 1.50 per litre up here right now and not getting any cheaper so 3 inch lift and bigger tires id like to avoid in the near future.
My question is what, other then a suspension lift are my best options to improve approach and departure angles? Is it just bumper replacements or is there something else I'm missing? Id like to leave the bumpers as stock as possible for the time being. Although i do really like the Aluminum Pelfreybilt.
thanks everyone!
If you are willing to, I think a couple folks on here have trimmed the lower bumpers to gain some clearance. Obviously its permanent and I don't recall thinking it looked horrible but not exactly great either.
Unfortunately your options are some what limited without lifting - while normally frowned upon you may be a good case for a spacer lift.
Not gonna like the answers I'm gonna give you but to get more clearance:
1. go up to 285's in C load
2. get a spacer lift on top of your xreas will give
3. replace your front/rear/and bottom door panels for trail edition panels.
4. buy a beater lc80 or jeep
My buddy did options 1 and 2, for playing around on service roads and what not, but he can't play on rocks. He ended up buying a crappy LC80 to play around with.
Replace the front lower bumper with a Pelfreybuilt aluminum. No cut replacement option, you don’t have to add a winch, so the weight difference would be negligible. Or you could do a Limited to SR5/Tral Edition Front end swap.
Trimming your plastic will net you significantly more approacha and departure clearance than a spacer lift, if it was me I wouldn’t mess with a lift. I dented my Limited’s lower bumper with probably less than 1k miles on the odometer, they hang down super low.
I have seriously been thinking of replacing the front bumper with the Pelfrey Alum one however that would still leave my back bumper and believe it or not I find I scrap the back more then the front. Does anyone here with s Limited have pictures of what a “trimmed” front and back bumper look like?
lindwlson982
