5vz-fe what in the heck is this thing on the block
sleepydad
Senior Member
drivers side between the oil cooler and the oil filter?
never seen it before what is it?
<a href="https://imgur.com/ahMN9Sw"><img src="https://i.imgur.com/ahMN9Swl.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/lOHpe6o"><img src="https://i.imgur.com/lOHpe6ol.jpg" title="source: imgur.com" /></a>
baja1; said:
good question! here's the other end with the pan removed....just a hole.
well the other 5vz I have sitting to the side does not have it all. it's just not there. I honestly don't ever remember seeing it.
I need to figure it out because this is a re-man from yotashop I'm installing. so I guess I will call them tomorrow and feel dumb and have to ask? like do I just put a cork in there or what?
it's a re-man
I even had the upper end bead blasted
<a href="https://imgur.com/eba6lhG"><img src="https://i.imgur.com/eba6lhGl.jpg" title="source: imgur.com" /></a>
and sand blasted the easy stuff myself and rattle canned it
<a href="https://imgur.com/wRyKbu3"><img src="https://i.imgur.com/wRyKbu3l.jpg" title="source: imgur.com" /></a>
it's going to look brand new until I spill something all over it, but it will look sexy for 10 mins so it's worth it.
my other 5vz looks like this and I honestly can't ever remember seeing anything in that spot ever.
<a href="https://imgur.com/YpVWUlv"><img src="https://i.imgur.com/YpVWUlvl.jpg" title="source: imgur.com" /></a>
JDM engine dipstick location. Where was the engine block from?
-Charlie
It’s a reman from yotashop, so there must be some sort of plug then, because the engine mount goes right over it. I cant see how a dipstick would go through the engine mount.
Jdm engines must have very different mounts.
It's a plug. The earlier blocks had two locations. I can't remember if it was 2WD vs 4WD, or exactly what it was. When doing a solid axle on a 5VZ, lots of guys use T100 pans, because the front has more clearance. When using the T100 pan, I think you use the more rearward location for the dipstick.
I had to swap it on my engine when I did the 3.4 in my '92 4R. It's been 10 years ago now, so that's all a little fuzzy.
The T100 and the earlier and 5 lug V6 tacomas used a rear sump pan with the dipstick in that location. for the 6 lug tacos and 4runners that got plugged and the dipstick goes through the oil pump.
Definitely for a dip-stick. or an oil temp/level sensor.
-Charlie
that thing IS a plug....or at least on my 97 it is.
Toyota Part No.: 11444-62020
PLUG, HOLE
Yotashop apparently does not read their own orders when you tell them you have a 2000 4runner. Instead they just give everybody 2 dipstick holes.
I was able to get it out so now again the story of my life. Waiting on parts.
In case anyone hasnt answered it yet.... It's the JDM dipstick location. If you are doing a 3.4 swap in to a 2nd gen you have to punch a hole their so that you can clear the oil pan.
