Coolant pipe in 5VZ-FE block valley - nut broke
cruisercorner
Junior Member
Im doing a top end refresh on a 5vz-fe in a 97 4runner, and when i pulled the coolant pipe that runs through the valley, i broke the nut holding the pipe at the back of the block valley. Is this something that I need to worry about fixing, or will the lower intake keep enough pressure on it to stay in place? I did replace the foam about the coolant pipe block plate with some fresh closed cell foam.
Here's a link to a pic, not sure why my insert pic link didnt work... Shared album - Tone Southerland - Google Photos
tTVsaKZoVU8PDX44A
oh man, how secure does the pipe seem with the missing bolt? 10mm (6mm) are so easy to snap too. maybe some high temp RTV to hold it there as that is a major headache to get that bolt threads out of that hole...:-(
2001ATL
