85 with Fuel delivery problem....
88THMPR
Hey Folks,
The 85 22RE 4Rrunner that I picked up was missing a few items when I bought it a short while ago.
Missing and now replaced items were:
Transmission
Ignighter/Coil assembly
Alternator
Battery
Female lead for the O2 sensor.
With all installed the motor does crank, has strong spark but no fuel.
I did spray starting fluid into the throttle body and it fired right up.
I pulled the fuel rubber hose from the fuel hard line on the passenger side of engine comparment and it was DRY. There is 2-3 gallons in the tank. I don't hear the pump when I turn the key - should I?
Fuses are all good.
Aside from pulling the fuel pump, what else should I try to remedy this problem?
Much thanks in advance for any and all advise!
Norm - High Desert
If you jump the +B and Fp terminals on the engine check connector it will bypass all the interlocks and apply power to the fuel pump.
ian2328
