MWS
hey all i'm havin' one hellof a time with my brakes. I heard a grinding in the front right side so I went a picked up a set of pads and rotors, well then I found out I needed wheel bearings and calipers. Then when that was all installed the booster failed, replaced that then the master cylinder went. Replaced that and now for some reason I can't keep the system to hold pressure.....I can pump the pedal about 10-15 times and get pressure in the system, have bled the brakes 4 times now. The problem is I can't keep pressure in the system. I have checked all the lines and there are no leaks and I went so far as to get ANOTHER master cylinder and put that on. When you pump the breaks to get pressure the minute you let off the pedal all pressure is gone. When my buddy had his head under the hood he heard a "release of pressure" from the master cylinder. I'm assuming that this means that the reman master cylinder i have is bad. Any halep anybody can give me would be much appreciated. I am picking up a NEW mastercylinder tonight and gonna try that but i'm pretty stumped.....HELP!!!!!
:awais:
:bash: :dammit: :sobbing: :cursin: ****I think those should take care of what I have been feeling for the past week******
