883 coils
Whackmaster
I'm thinking of getting some 883 coils. On the web site it has a note,,( NOTE: 882 and 883 coils require matching OME 90004 front shocks ) but I want to use my stock shock since they are in good shape.Has anyone used these with their stock shocks? Thanks
stock ones are not as long. since your getting some lift your shock will become your stopper if you flex while off roading. this will make them go bad sooner and you will need new shocks anyway.
better to at least do the front the right way the first time to avoid changing out them a second time cause you will need an alignment each time you change shocks. rear not so much.
