90k service
Supra725
Hola guys and girls.
I have a few questions about the 90k service.
So far I have done the following.
-new brake pads and rotors.
-transmission fluid change.
My question is, what's in an 90k service.
-New Shocks(coming in next week)
-Spark plugs.
-PCV Valve.
-Front and Rear Differential Fluid.
-Timing Belt.
-Water Pump.
-O2 sensors?
-Power Steering and Brake Fluid.
What else am I missing from the list?
thanks.
Xfer case fluid, grease up drive line components, fuel filter, general status check of components under the car.
You don't need to replace the O2 sensors. PCV valve is not mandatory either. You can simply check it. Shocks are also a check item.
I'd do thermostat with TB/WP. On the other hand, I'd wait for a code with O2 sensors, they are expensive (but easy to change) and I'd get every mile I can out of them. Plug wires are an optional, but I did them at 100k.
In your under car check, pay close attention to swaybar bushings, end links, and steering rack bushings. These are all things I needed at 90-120K and I baby my truck--offroad only two or three times a year.
I got an question.
Which oil would you guys recommend for the transfer case, front and rear diff?
Mobil 1? Amsoil? Royal Purple?
Also, what weight did you guys used?
thanks
