92 4runner no spark
tyson8813
My 92 toyota 4runner V6 4x4 is not getting any spark period. Replaced computer, distributor, module, and traced all wires and fuses are good. Please help asap. I just finished school and I must have a vehicle in running form YESTERDAY.
92 4runner no spark?
92 4runner no spark? help
Maybe you should post this in a few other areas of the forum.
My next guess would be Crank or cam position sensors.
the computer i bought didnt match numbers with the original. researching online has lead me to beleave it is important. does anyone know anything about the computers in the 4runners? the one i bought was from a parts store and didnt match numbers. the guy from the store didnt have answers. i found one on ebay with matching numbers. what do u think?
You might check with the second gen guys...they probably know more.
we used a coil igniter off of my buddys 94 with no luck. the computer i bought didnt match numbers with the original. researching online has lead me to beleave it is important. does anyone know anything about the computers in the 4runners? the one i bought was from a parts store and didnt match numbers. the guy from the store didnt have answers. i found one on ebay with matching numbers. what do u think?
The computer would be the last thing I would replace, as they don't typically go bad.
What codes do you have if you jumper the T1 and TE1 connections in the diagnostic box?
Can you put back in the old ecm?
Here is the troubleshooting diagram......
http://www.ncttora.com/fsm/1990-199...f/95rmsour/1995/954runne/ig/3vze/onvehicl.pdf
and the service specifications...
http://www.ncttora.com/fsm/1990-199...f/95rmsour/1995/954runne/ig/3vze/services.pdf
I did put the old computer back in and took the new one back. Power is getting to the computer but not leaving. i feel i replaced all i could replace. i was told that it wasnt that uncommon for 2nd gen 4runner computers to go bad. everything is telling me its the computer but with know success on the new one, it has me second guessing.
I would start at page 13 and test again just to be sure...
http://www.ncttora.com/fsm/1990-199...msour/1995/954runne/eg2/mfisyste/troubles.pdf
I would clean and test all the grounds related to the ECM and battery also.
will do, although my grounds look good, ill run through them too. im suposed to be driven from az to boston on monday. This truck will make it no problem and is fully ready to go, if it starts that is. im stressen....thanks for your help, and if you think of anything else...
Just a thought, you will probably get more responses from the guys over at the 2nd gen. page....this is the 3rd gen. page.
The engines, computers, etc...are different.
3.0 V6 & OBD-I for '89 - '95 ( 2nd. Gen. )
3.4 V6 & OBD-II for '96 - '02 ( 3rd. Gen. )
Good luck!
Hello,
I am having the same issue right now with my 91 4runner....The ECU needs to have exactly the same numbers...I got one at a junk yard....will have to see tommorow if it works...
the number that has to be the same is the 89661 number on your computer...
I had a jaguar with electrical problems and remembered thinking,....man I wish i had a toyota...seems you have to be careful what you wish for...
Let me know what happens as i am in the same boat you are... I will let you know im the ecu fixes my problem...
If anyone else wants to help out here is what happened...I changed my plugs ...the wires and distributor cap and rotor...Came to fire her up...nothing...no spark at coil...got other coil and igniter from junkyard...still nothing....got distributor and installed it...still nothing....checked all the fuses all good...one thing which is weird id that the check engine light does NOT COME on when the key is on the ON position...Engine cranks but 0 spark...
No! Plz no... From here: http://www.toyota-4runner.org/new-m...r-org-new-members-please-read.html#post440375 Check out rule #8. If you post and want to move it just ask an active moderator to move it. A quick PM will usually get it done. If there's been no responses consider deleting it and re-posting it in a more appropriate sub-forum. Thanks:D
Threads merged and good luck!
:cheers:
