92' A340H shift Solenoid Help!
Bought them! I will check to see if this will fix the problem.
Praying that it does.
Will update when installed.
[MENTION=233783]ClintR2[/MENTION] that may have been the incorrect link.
Hoping you double checked it was for the A340H transmission. There are several A340's out there and some sellers don't specify the A340H
[MENTION=101372]Dropzone[/MENTION]
Where exactly can you tell what model transmission you have?
I have a plate in the side of it but does not read like any numbers listed.
What Solenoid is what? Location of what solenoid is 1,2 and lockout-- Can not seem to get a straight answer on this.
Got it all installed.
Not much metal shavings in the pan. Just very fine shavings and like dust.
Truck had more power in the low gears.
However is is reading a code 41. TPS . Changed it and not difference.
Car runs very ruff and idling high. Adjusted the timing and still no difference.
The check engin light is off but still runs very bad.
I am stumped.
Any idea what it could be??
Bad TPS or widening harness??
I am stumped.
your throttle could actually be out of position..
4Crawler has a pretty could write up on trouble shooting the TPS
Toyota 22RE Throttle Position Sensor
you made want to try this first though, it is a quick and easy to do.
Before re-adjusting or replacing clean throttle body,reset ECU by disconnecting battery or removing 15 amp EFI fuse for at least 1 minute.
I am having shifting difficulties in my 95 automatic tranny. The engine revs to 4000, mph slows and it won’t shift easily. I think it’s my shift solenoids, been researching the Axiom tech ones. They worked well for you? I’m ho-I gotta it is my shift solenoid
Laredotx
