92 moon roof glass cracked
madmanhiker
Anyone have any advice as to how to get this repaired or replaced? I've searched ebay with no luck. Can Lee and Cates or someone like that replace the glass? Any suggestions? It's just cracked, I have no idea how it happened, not shattered (yet) so I'd like to get a jump on it before it gets worse. Thanks in advance.
Is it a factory sunroof? If so, check all the junk yards in your area, most of these are usually pulled and stuck on a shelf somewhere.
If its aftermarket, you'll need to figure out who the manufacturer is and see if you can find a replacement for that particular model/part number.
Worst case scenario if it is an aftermarket unit is you'll need to have a larger one installed, if there's enough room for a larger one.
Do you have a retracting moonroof? Or is it the one that just pops up and stays cracked open? If its the later, any pickup/tacoma from 87-03 I think should work. My buddy's 01 sunroof fits on my 89 4runner.
