fattest1here
i am having issues with my truck tryin to start! i am only getting 1 click when i turn the key on. if i do this about 10 times it will start and run just fine. i believe is the starter but not 100%.
if it ends up being the starter are there any suggestions on the best way to change it? btw... the battery and terminals are about a month old. as weel as the timing belt and accessory belts. everything has worked fine since i had to do the crank/cam seals in March. thanks for the help as usual guys :moping:
