94 Has a Slight Tilt
mjquillici
I'm trying to figure out what's going on. Distance from both rear wheel wells to ground is 35 inches. Distance from front passenger wheel well to ground is 37 inches. Distance from front driver wheel well to ground is about 37.5 inches. Not sure how that's possible, but it's not sitting quite level. What could be causing this, and how do I fix it? I have no idea. . .
^ This. A 1/2"? Quit worrying and go drive the darn thing.
Could be a number of things... your t bars could be off a turn causing that, a long life of full gas tanks could be causing a bit of a sag on the pass side, since your measuring fender to ground, it could be one of your tires has a bit lower PSI than the other.
When you sit in the driver seat, I bet its level :shrug:
H.Sikina
