94 runner water coming from under dash on passenger side
ivbutch
I have a 94 4runner. Every time I use the A/C and I make a turn water comes out from underneath the dash on the passenger side. I know it is A/C related because it only happens when the A/C is on. It is NOT water leaking in from the antenna, windshield, or sunroof. I've searched the forum and notice other have had similar issues but none of them said how to fix it. Help in finding a way to fix this. Or, do I need to send it someplace to get fixed?
Thank You
Sounds like the dehumidifier drain is blocked, causing condensation and moisture to leak and drain inside. The drain is usually along the firewall or near the floor board on the passenger side. You might be able to see it under the hood or truck.
If you're comfortable in taking apart the dash near the glove box and the duct work, I would start investigating there as a starting point. Take a look around and see if someone has a service manual available for your 2nd gen or the 1989-1994 trucks.
Good luck.
2001ATL
