95 4RUNNER water/coolant leak + false idle
hellachef
Hey there, so i'm brand new on here, been searching threads for a week and haven't seen a post like mine, so i figured i'd give it a shot.
when my 4runner has been sitting overnight and i start it in the morning, after about a minute or so, instead of dropping to normal idle, she will gradually increase in RPMs up till about 2300 over the course of 4 or 5 minutes, then drop to a normal idle.. yesterday it was overheating for the first time ever driving on the highway, and i came home, let it cool, added water into the radiator and sure enough there is water leaking gradually somewhere near the water pump.. i took it in, mechanic was SURE it was the water pump, i'm wondering if the thermostat or fan clutch is what's actually wrong, would it still be leaking water/coolant? there is no oil in coolant or coolant/water in oil. thanks!
When you are low enough on coolant the IACV will get air bubbles which will raise the idle until warm coolant flows through it and starts closing the valve. I would address the leaking coolant first as I am sure they are related.
Thermostat is a possibility, but fan clutch should be ruled out as any water coming from it would be out of the water pump. Do these 3.0 engines have weep holes on top of the water pump?
EnviroHokie
