96 4runner going to the right(extremly)
Denet
My 1996 4runner Limited Edition 4WD goes to right suddenly. I just had alignment done 3 month ago. It is going so much to the right at 30 mph, I can't go any faster to keep the car going straight.
Is the steering going out or something wrong with alignment?
Any suggestions would help. Thank you.
Extremely hard to tell without inspecting it, but here are a few things to check out...
Check tires for obvious signs of damage or extremely uneven wear. Check tire pressures. Front and rear.
Are the lug nuts still tight?
Brakes may be dragging. (Is one side getting hotter than the other? Any burning smells coming from the brakes?)
Raise the front end and spin the wheels by hand, listen and feel for anything unusual.
Suspension may be stuffed. (Broken coil etc)
Pull the wheels off and check all nuts and bolts that you can see. Look for worn out rubber bushes.
When stationary does turning the wheels full left and full right feel and sound the same?
Hope this helps a bit.
Thank you,
Thanks for your suggestions. I check all you have listed and found a lot parts need attention.
But it turned out the alignment that was done incorrectly and it got loose. I took back to the dealer and they took care of it.
NVBASSJUNKIE
